| Blitz I-Color. The controller is reading all functions properly (RPM, boost pressure, fuel pressure, etc.) However, it is not limiting boost. I have the "IN" port on the solenoid tubed to intake pipe fittings (ASH's pipes) just ahead of the TB's. The "OUT" port is tubed up to the wastegate actuators. The controller is set up to control "WG" and set on manual control. I have the boost limited to 5psi. It's still not limiting boost. Is there a way to bench test the solenoid? I may email DVDBurn to see if he has worked on solenoids. Thanks for any help.
